Re: Reversed H or M
Posted by NDS on May 25, 2008 at 16:44:36 from (64.12.116.73):
In Reply to: Re: Reversed H or M posted by Janicholson on May 25, 2008 at 13:36:36:
On H and M when ring gear is flipped it is under shift lever. You can pull oil fill plug and see that ring grar only clears frame cover by about 1/4 inch and that is why shifter has to be moved to other side. In cotton country a lot of the retired high drum pickers that were reversed in drop boxes were reversed again (double reverse =foward travel) to get them running foward in high clearance configuration and used as spray rigs and no one I know of has not been able to do it without moving shifter.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
