Re: Voltage regulator Bob M and/or others
Posted by Bob M on May 27, 2008 at 05:52:33 from (151.190.254.108):
In Reply to: Re: Voltage regulator Bob M and/or others posted by HENRY E NC on May 26, 2008 at 20:09:37:
Henry - If the tractor were mine I'd put a crowbar in my wallet, purchase a new regulator and be done with it (will cost you less than your next replacement battery!)
That said, and if you still feel like messing with it, the regulator relay is adjusted by gently bending the spring hanger. It is best accomplished with pair of small needle-nosed pliers. Here's how I've done it:
Make sure the battery is fully charged. Remove the regulator cover. Place a DC voltmeter across the battery. Start the engine and run it at full governed RPM for a couple minutes before proceeding.
Now VERY CAREFULLY grab the regulator spring hanger with needle nose pliers (don't touch anything any other metal with the pliers!). While observing the voltmeter, bend the hanger very slightly to reduce the spring tension.
When the voltmeter reads 7 - 7.25 volts, stop! Let the engine run a minute or two and check the voltmeter reading again. If it's not 7 - 7.25 volts go back and bend the hanger again as needed. It may take several tries to get it to spec.
As I mentioned before regulator setting is a fussy, sensitive adjustment. And as "Bob" points out above, one slip with the pliers and the smoke will come out of the regulator - you will wind up buying a new regulator anyway! (Don't ask how I learned this....)
