Re: Plumbing loader on 300 Farmall
Posted by Hugh MacKay on June 09, 2008 at 17:58:55 from (209.226.247.110):
In Reply to: Plumbing loader on 300 Farmall posted by Matt Compton on June 09, 2008 at 16:28:15:
Matt: If the spool valve that came with your Freeman loader is a power beyond valve, just tee into the high pressure line between pump and 300 own control valves. high pressure is the small one. I ran my 300 that way for years, 5 double action remote control valves. I took the steel lines off, cut the high presure line about 1' from curve at back end. A welder brazed fittings on each end of the cut. then it was just teeing in and mounting the valve.
