350 utility HYDRA- TOUCH SYSTEM
Posted by DAN S on June 20, 2008 at 09:50:33 from (66.39.171.19):
I BOUGHT AN INTERNATIONAL 350 UTILITY A FEW MONTHS AGO, I CHANGED THE OIL IN HYDRA-TOUCH SYSTEM, PREVIOUS OWNER HAD AW32 IN SYSTEM. I REPLACED IT WITH HI TRAN OIL, NO PRESSURE TO POWER STEERING OR 2 POINT OR REMOTES. DRAINED SYSTEM AND TOOK TOP OFF OF THE TANK TO CLEAN SCREEN, NO SCREEN, THERE IS AN IN LINE CHARLYNN SCREEN IN THE SUCTION LINE, I ALSO CLEANED THAT. PUMP WILL PUMP OIL BUT NOT PRESSURE, CAN ANYONE HELP ?
THANKS
DAN S
