Re: '45 M - hydraulics low?
Posted by billde on July 20, 2008 at 16:13:22 from (72.26.91.191):
In Reply to: Re: '45 M - hydraulics low? posted by Kevin Statz on July 20, 2008 at 16:04:51:
The plug you have circled is the fill plug for the belt pulley drive. That in turn dumps into the tranny. The hose to the right of that and slightly forward would have been the original fill and level check port.
You have an add on aftermarket pump using the original hyd reservoir. You may be able to add oil by using one of the pipe plugs directly below the Hyd valve.
