Re: more 560d clutch problems
Posted by Janicholson on July 27, 2008 at 18:32:42 from (66.173.50.156):
In Reply to: more 560d clutch problems posted by Arkie on July 27, 2008 at 18:23:57:
Assuming you have the Throwout bearing in place. The clutch will need to be adjusted. New disks change the adjustment radically. The adjustment will position the Throwout bearing so that it does not spin, but is very close to the fingers. The rod from the pedal must be changed in length to do this. The pedal should have 1" of free play (measured where the pedal hits the foot platform when it is all the way up) before the bearing contacts the Fingers. THis freeplay defines how far the pedal can push the fingers. JimN
