Noisy H
Posted by GordoSD on August 05, 2008 at 13:57:53 from (66.115.200.140):
Now that I've had the H out of the shop and test driving it I seem to have a transmission problem. The only thing I did relative to the transmission was to rebuild the shifter lever, and replced a broken LH bearing cage. I installed a used bearing cage from a salvage yard, and not knowing the tolerances involved I did not place the shim that was there with the original.
When I start the engine I hear a pretty good vibration/rattling about in the middle of the trans platform. It stops when I depress the clutch. I used 85-140 oil in the trans.
What parts of the trans are moving, at idle with the tractor in neutral? And what can I check without removing the platform?
Gordo
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
