Re: OT: Finally figured out the real reason
Posted by Steven f/AZ on August 08, 2008 at 12:32:57 from (216.67.213.217):
In Reply to: OT: Finally figured out the real reason posted by Hugh MacKay on August 08, 2008 at 03:59:50:
Yep, them front wheel drives just don't last. Darn Honda cars are only good for around 250,000 miles before you have to put a CV axle in them - that is, if you push it a little bit.
http://www.hondabeat.com/highmiles.php
The unfortunate reality is, American made cars went downhill while the foreign made cars improved. NOW, the American made cars are beginning to catch up again - but the damage may already be done.
