Re: Hugh, got a question (or two)
Posted by Hugh MacKay on August 20, 2008 at 09:25:41 from (209.226.247.22):
In Reply to: Hugh, got a question (or two) posted by dianah on August 20, 2008 at 04:18:52:
Diana: This is just a thought, but the transmission may be over full. with tractor on lever ground remove the fill to level plug. Be prepared to catch oil. All IH tractors of that era will leak if transmission is over full. I expect you've had close to the same amount of rain we had this summer. I know your tractor is parked outside most of the time. Those tractors are prone to water running down the gear shift lever and into the transmission during heavy rains.
Do this first, then worry about seals if not over full.
