Posted by Bob M on August 25, 2008 at 13:26:59 from (151.190.254.108):
In Reply to: H charging prob;lem posted by PetePequawketfarm on August 25, 2008 at 10:42:53:
John T said: Like Jim, Im NO FAN of the 8 volt system as a band aid approach to fix a problem which a good heavy duty battery and 00 Gauge cables might cure, especially on an lil H although Id cut a guy a lil more slack if it were an M lol[/quote:ef87d7e1d5]
I agree 100% John T(!)
John T said: A genny dont necessarily know its voltage, thats a function (in great part within limits) of how fast it turns plus how much current is pumped through the field windings. So....
1) If its a cutout relay I think it will still charge an 8 volt battery NO MODS NECESSARY (notwithstanding cut in/out voltage adjustment) although maybe not at any super high charge rate.[/quote:ef87d7e1d5]
Yup. A cutout system is not much insensitive to system voltage. A "6 volt " genny and cutout will charge an 8 volt (or even a 12 volt...) battery - though at a lower rate and a higher cut-in RPM.
John T said: (2) If it has a VR that has 2 coils and one (not the cutout relay) is a current controller ONLY, I think it will still charge with no mods (other them perhaps cut in/out voltage) cuz the current control relay can still do its job.
The 2 relay VR's I'm familiar with (Delcos on IHC and MinneMo stuff) combine both the current and voltage regulating funtions into a single relay. They're extremely difficult to field adjust correctly to work on 6 volts - for 8 volts they're virtually impossible to get right.
[quote:ef87d7e1d5="John T"](3) HOWEVER if its a 3 coil or 2 coil relay and the one relay is a VOLTAGE CONTROL RELAY (or a combination current n voltage relay on that second coil) I think it needs some significant adjustments (air gaps or spring tensions) to charge an 8 volt battery.
Yes again. Need to increase the spring tension on the VR relay to "bump" the regulating set point from around 7 volts to a tad over 9 volts. (My experience is this is easier said than done however....)
[quote:ef87d7e1d5="John T"] PS follow Jims advice about Polarity and be sure n polarize the genny and have a VR thats compatible with your ground polarity.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
