1950 Farmall H hydraulic belly pump, I need HELP!
Posted by DickelDawg on August 27, 2008 at 08:12:41 from (67.142.130.11):
Last winter the hydraulic pump on my H developed a major leak. I pulled the pump but hadn"t gotten around to replacing the output manifold gasket until yesterday. I thought everything went well on reassembly BUT...I can"t get the pump to pickup fluid. No output pressure, no matter what I do. I have bled the cylinder, pressurized the oil sump. And all I can get is a small flow of fluid out of the bleed hole on the cylinder. NO pressure at all.
I need help!
Thanks in advance
