At the valve on the tractor, It should be a 3/8" flare fitting. you should be able to get a fitting/hose off of a gas grill,camper trailer, or some other propane appliance that will hook up to your 20# cylinder and at the hardware store you should be able to get/use brass fittings to get you from the threads on the hose to the 3/8 flare. disconnect the copper line from your tank, and hook up your temporary line. Make sure you check for leaks with soapy water. if you have a leak it will bubble at your new connections you made.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
