Re: Farmall 706 LP tractor wont start
Posted by martin simmons 38655 on September 05, 2008 at 18:30:15 from (74.251.41.39):
In Reply to: Re: Farmall 706 LP tractor wont start posted by farmallkid1958 on September 02, 2008 at 04:01:33:
thanks for all the help. i haven"t setup my temp propane tank yet cause we are receiving alot of rain from hurricane gustave up here in northern mississippi. i have just a couple more questions so even tho i have a carb with a slot for the choke cable because i have the vaperizer i dont have to use it. also do you know where i can get an ignition switch and key. someone broke the key in it and destroyed it trying to get the key out [they used a screwdriver]. and do you think i should use a tank sealer kit on the tank. i am not sure but i would think there is a little water in the tank cause. there is a spout on top and i really wont to say it it the filler neak and the tractor has not been covered up. i have seen a little puddle of water of in there but nothing big just like a bottle caps amount in there. and if you have any recommendations on what to do if there is water in there. once again thanks for all the help : )
