Re: Farmall 504 Weak Hydraulic Continuin' Saga
Posted by Hugh MacKay on September 05, 2008 at 02:29:21 from (216.208.58.173):
In Reply to: Re: Farmall 504 Weak Hydraulic Continuin' Saga posted by TractormanNC on September 04, 2008 at 18:10:31:
Tractorman: I'm not sure your concept of which pump powers what is correct. The 504 may be different, however using a semi-mount plow on 656 and large chassis 06, 56 and 66 tractors, hitch is on same pump with remotes, or at least tied in some way. I'm not an engineer or a mechanic however when you pull both 3 point lift and remote for rear of plow at the same time, the hitch will raise to full height before the remote starts to lift the rear of plow.
