Leaking 140...???
Posted by KRS_MED on September 06, 2008 at 06:04:20 from (74.244.168.169):
Well finally got around to doing a little bush hogging after repairing the starter issue and replacing the manifold. I started to notice there was gear oil leaking from the PTO shaft and from some were around the rear axles. Replaced the PTO seal and all is fine. But I can not locate exactly were the leaks are around the rear axles. Is there any common place that they have been know to have leaks in this area?
Also what all would be involved in repairing?
Hadn't used the tractor in several months, but when I parked it all was just fine. Thought that I had taken care of all the problems befor I ever put her to work. I guess you can never have it all done with older equipment.
Thanks,
Keith
