An idiot light wired (between switches IGN output and alternators lil side No 1 terminal) in can prevent backfeed ignition run on so the tractor dont keep runnign even after the ign switch is turned OFF
YES ITS IMPORTANT
As posted above I prefer an idiot light or a 10 ohm resistor over a diode to prevent run on although either will work if wired correct
Check for BAT INPUT voltage getting to the switch fed off the ammeter cuz if its not that can prevent the ignition from working and prevent charging !!!!!!!
I think you just lost power to the switches input, get a test light n go to work !!!! Likely a loose or pulled off hot feed wire to the switch
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
