Re: 12V conversion not starting/charging
Posted by Janicholson on September 11, 2008 at 10:22:47 from (199.17.6.128):
In Reply to: Re: 12V conversion not starting/charging posted by John T on September 10, 2008 at 20:27:07:
John, If a person were to utilize a simple key switch for automotive use (with Off--ACC--Run---Start) and wired it so that the Start position would be used to excite the delco #1 terminal, Not start the engine, It would be a pretty simple way of making the tractor more secure from casual operation (Key) and to start it charging. What do you think, JimN
