Re: f20 engine (parts missing?)
Posted by James Herrman on September 13, 2008 at 15:49:40 from (66.249.34.40):
In Reply to: f20 engine (parts missing?) posted by casered on September 13, 2008 at 13:51:00:
Not an expert by any means, but think I know what you are talking about. Believe this to be under head on right side there is a hole. There should be (at least on mine) a brass deflector piece which I believe lets oil drain back into crankcase, but prevents oil splash or whatever from entering the head area from the engine. One way or another, there is a piece that goes in there. Let me know if this helps. Not sure I got the direction in which it works, but had to make one for my regular should be close to a 20. Maybe someone else knows. Have not ran across others that knew about this hole and the piece that goes in there. jim in Ill
