Re: Farmall A and Super A Front Rims
Posted by Hugh MacKay on October 04, 2008 at 13:14:20 from (209.226.106.182):
In Reply to: Farmall A and Super A Front Rims posted by Brian2 on October 04, 2008 at 10:53:21:
Brian: You have two different type rims, adjustable and non adjustable, they will not interchange on the hubs. All those tractors had 5.00 or 5.50 x 15 on a 3" wide rim.
The non adjustable rim is held on by lugs similar to older heavy trucks. The adjustable rim has lugs welded to the rim.
There is one other option, that being 4" x 16" rims, only available as adjustable. They take 5.00 or 5.50 x 16 tires.
