Re: Help solve a Super A question
Posted by ScottyHOMEy on October 22, 2008 at 06:25:29 from (70.105.238.197):
In Reply to: Help solve a Super A question posted by Larry in GA. on October 22, 2008 at 05:29:45:
Two ways to go at this.
1) If the A was still 6 volt, then it was probably set up for pos ground. Even if your buddy swapped grounds, it wouldn't hurt it as others have said. However, if he didn't repolarize the generator it won't charge the battery, and he'll have run the battery down, mostly from starting it and maybe using the lights. If it has a battery ignition, that will run it down, too though you can run quite a while before the ignition will stop if you're not running lights at the same time. If it's a battery ignition, he should also have reversed the leads on top of the coil. If it's got a magneto, that last point won't be a factor.
If he clapped a 12v battery onto a 6 volt tractor with battery ignition, he may have burned up the coil and the points are probably burnt.
2) If the tractor was 12volt with a generator (unusual) he would still have to polarize the genertor. If 12v with alternator (far more common), then you're down to the usual troubleshooting for anything that won't run. Start by checking the condition of the battery. If it's low, search on here for Bob M's wiring diagrams to make sure everything is hooked up right, and then look for JohnT's troubleshooting sequence to try to isolate the problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
