Posted by gerritt in michigan on November 15, 2008 at 09:22:47 from (69.244.165.164):
In Reply to: #@$%*##$ charging system posted by Gerritt in michigan on November 14, 2008 at 10:27:34:
the end result is negitive charge on the ammeter.Here is what I have,+ on battery to ground. - on battery to starter switch.same post on starter swith to - on ammeter. +on ammeter to fuse on back of 4 position switch. same fuse to on off switch , on/off switch to- on coil,+ on coil to distributor...+ on ammeter to bat screw on voltage reg or cut out. gen screw on voltage regulator/cut out to A stud on generator. F screw on vr/cutout to F stud on generator. F stud on generator to field resistor on back of 4 position switch. 1. is this wired right? 2. If it is and I have to start spending $$$$ wouldn't I be better off going to a 12v altinator system than sinking $$$$ into a 6v generator ,voltage regulator or cut out or whatever it is?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
