Re: Brake Pedal Shaft
Posted by NC Mike on November 16, 2008 at 05:24:34 from (68.221.19.69):
In Reply to: Brake Pedal Shaft posted by David Goode on November 15, 2008 at 18:01:09:
Forgot to mention that you shoulden't need to drain any of the fluid if you have the new seals in. I had to pull my shaft for another problem and no oil came out and the transmission was full to the top.
