Re: Farmall 130 excessive steering play.
Posted by Jobe Piemme on November 17, 2008 at 05:20:17 from (24.103.179.246):
In Reply to: Re: Farmall 130 excessive steering play. posted by Gene Bender on November 16, 2008 at 17:13:04:
Thanks for the help, I will do a total overhaul.
Question: is the steering arm a press fit? Would a pickle fork work for removing it?
Thanks.
