Re: Farmall 130 excessive steering play.
Posted by Gene Bender on November 16, 2008 at 17:13:04 from (67.55.226.167):
In Reply to: Farmall 130 excessive steering play. posted by Jobe Piemme on November 16, 2008 at 15:01:14:
I would remove the wholw steering sector for a complete overhaul. The arm you are talking about can be a problem to remove but with the whole sector removed it can make it easier to remove as the bottom section wont come apart until the arm is removed. I would replace all bearings and seals and bushings. The woodruff key is probably worn bad also. Parts will run about 50.00.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
