Re: M Farmall Napa 6v coil update...... Honda parts?
Posted by CNKS on November 20, 2008 at 18:51:07 from (216.144.104.128):
In Reply to: Re: M Farmall Napa 6v coil update...... Honda parts? posted by Dave Hollrah on November 20, 2008 at 18:38:45:
Some allow 12 volts for starting and run on 6 volts; I think 12 volts would fry the condensor. This subject has been gone over many times, I don't remember all the details. But I do know that the 460/560 use a ballast resistor in a 12 volt system.
