Hey Tractor Vet..... got a ? for you. Or, anyone else...
Posted by Dan Swanson on November 26, 2008 at 10:57:16 from (63.172.252.161):
I have an 806 with a single set of hydraulic couplers at the rear which controlled by the left lever. Want a second set. Ran two hoses to the rear of the tractor off the right side of outlets behind the fuel tank. I removed two pioneer FM couplers that were there and installed the two hoses to the rear with new pioneer couplers. Hooked up a cylinder and can't get the cylinder to move. I was assuming the right side had been used before because of the couplers. Is it possible that the linkage to the right valve isn't attached to the lever from the factory? Any Ideas? Thanks Dan
