Posted by Jim R on November 28, 2008 at 19:29:23 from (209.181.185.49):
I recently acquired a Farmall "M" and have not worked on one before so am not real familiar with these tractors. It will occasionally smoke very light colored smoke, mostly under light load or idle and seems to be using oil, more than normal. It doesn't smoke under heavy load. The smoke doesn't look like oil smoke, it is almost white. There seems to be no water in the oil, and the rediator level isn't dropping. I have done a compression test on it and all cylinders had between 100 and 110 lbs. and putting oil in the cylinders only brought up the compression a max. 10 lbs. The engine runs smooth and has lots of power. Does anyone out there have any idea what is going on and why is it smoking and using oil? What can I check for? Thanks for any help!!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
