Scotty , part# M-2572 appears to me to be attached (or cast/machined together) to the shaft that turns M2572. Then the shorter off center "pin " that the pitman bearing turns on and the threaded stub that holds it on is worn out.In fact the PO had welded the nut on to hold the bearing on. Anyway that is what I need to replace, but I can't see how to get it (the short off center pin and threaded stubb) off. Hope this clears it up some , Thanks, Tim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
