Re: 460 gear clash
Posted by Janicholson on December 14, 2008 at 06:55:38 from (64.83.205.193):
In Reply to: Re: 460 gear clash posted by Janicholson on December 14, 2008 at 06:40:35:
I believe that (as aluded to in the TV post above) the free clearance on the main throwout bearing to fingers can be 1/16 inch. if it is loose (and affected by the TA rod as it is activated when the clutch pedal is going through its travel) setting it to less clearance will not hurt anything. Many throwout systems are in constant motion and turn with the PP, having the slack in a different place. The key is not so much keeping the bearing from turning, but to keep the Fingers from being in a partial release tension, allowing the clutch to slip, and to have no apparent free play. Jim
