Re: 300 starting Problem
Posted by Janicholson on December 16, 2008 at 10:34:53 from (199.17.6.128):
In Reply to: 300 starting Problem posted by Siefring Red Farmer on December 16, 2008 at 08:24:59:
Do the followion test. Make sure the timing is at TDC when the points break (static timing) then=--- Put your good battery next to the starter on a table or stand. Run short cables from it to the solenoid. Start it. I bet it roars to life. The distance to the starter drops too much voltage. Use OOga JimN
