Best 350 pistons/liners for rebuild
Posted by Jake Winn on December 26, 2008 at 16:24:26 from (207.200.116.7):
I have a 350 engine i need to rebuild. #2 piston is badly stuck and there is a ridge in the other cylinders. What is the best rebuild kit out there. I can get a Tisco kit through work with pistons, liners, bearings, gaskets, valves, springs and keepers. These appear to be a stepped head piston. Has anyone used one of these kits and had what kind of luck did you have?
Also I have pulled wet liners from engines before but never a dry sleeve? Whats the procedure? I have access to a full shop for tools so thats not a problem.
Thanks for any help. Happy Holidays!!
