Re: Best 350 pistons/liners for rebuild
Posted by Janicholson on December 26, 2008 at 16:50:27 from (68.112.156.69):
In Reply to: Best 350 pistons/liners for rebuild posted by Jake Winn on December 26, 2008 at 16:24:26:
Tiscos are as good as any. They are commonly used. The piston should probably be removed prior to sleeve removal. The piston is probably swelling up the sleeve. This will make it near impossible to get out. Mechanical destruction of the ring area of the piston, drilling it out with multiple holes until it can be broken ouy works. A sleeve puller is needed to get the dry sleeves out the top. See images of them in Search For archives. Put H sleeve puller in the box. Good luck, they are pretty easy to work on. JimN
