Posted by CNKS on January 03, 2009 at 09:08:48 from (216.144.104.128):
In Reply to: 460 problems posted by Nebraska Kirk on January 03, 2009 at 08:15:56:
Rather than replace the ballast resistor, if it is suspect, you can get a 12V coil with an internal resistor from NAPA and remove the ballast. That's what I did to mine. But, it sounds like a fuel problem. Remember that that carb is not adjusted like those on the letter series -- turn the main fuel about 4 turns out and try to start it. If for some reason the oil pump has been messed with, it has to be "timed" to the distributer.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
