super a rear axle help
Posted by superAsquirrel on January 19, 2009 at 18:29:57 from (74.162.47.140):
I have a 49 Super A that is leaking rear end grease from around the brake housing on the right side.It is dripping out from the slot where the brake rod enters the housing.I will note that I am a novice at tractor repair and am not sure if there is a seal or gasket needing to be replaced.Any help or guidance would be greatly appreciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
