Ok, I got it. That thrust bearing is in perfect condition. The one needle bearing on the rock shaft is frozen up and the other turns but sticky. I'll replace both. Guess I will have to replace rock shaft bushing and seal as well because I believe you have to drive out the needle bearing from the outside. My NAPA dealer can get the Torrington BH 68 bearings for $5.10 each and the 1/2"x 5/8" x 3/4" long bronze bushing for the gov casing. I'll buy new Gov spring and gov shaft bumper spring, too. Really, the only problem I can find is the speed control lever shaft is wobbly in the Gov case other than that the old '51 gov looks pretty good. The gov was not working at all. I set a throttle opening it would stay there regardless of engine rpm. Not like my Cub which holds speed regardless of the load. Anything else I am missing before I order the parts??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
