Re: Re: Super Charging
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave on April 04, 2000 at 18:18:38 from (128.113.170.149):
In Reply to: Re: Super Charging posted by Dave on April 04, 2000 at 11:21:06:
What I posted above does not make sense as far as the negative lead from the battery to the starter goes. If you pull this, the ammeter will read zero because it is in the circuit after the starter. With the tractor off, see if there is any discharge from the battery as I described, and if there is any, then you have a ground (assuming lights are off) somewhere between the ammeter and everything it connects to. If there is no discharge indicated, then you are leaking current to ground somewhere before the ammeter, I would say in either the starter switch or the ammeter box itself.
Post A Followup
: Re: Re: Re: Super Charging
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
