bc the 2606 does use the same flow divider as a 656 I see. In that valve the orfice is not in the spool but is a seperate disc pressed into the casting, on the end of valve where the two large lines come in ,it is under the middle smaller plug. Haven't seen any of these type spools wear much at all , have had some of the disc's come out , bust up etc. That usually causes a different type of problem though as all the pump supply then goes to power steering causing lines to vibrate , noise, break etc. The valve on the other end, relief valve does have an adj screw but is factory staked. Could work loose and cause low pressure, or o-ring on bottom end of valve could be bad. One other thing, some of the 656 tractors had a T screw in that center fitting, the idea was to screw that in making cold starting easier. That was somebody's day dream I guess. but if you did have that on your valve you would want to be sure it was not screwed in part way. What one needs of course is a inline flow rater to check flow and pressure but am sure that is not an option so you just have to keep trying different things and picking people's brains.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
