Posted by Mark W. on February 17, 2009 at 08:55:25 from (64.83.132.2):
In Reply to: Re: super a clutch posted by ScottyHOMEy on February 17, 2009 at 07:33:59:
Thanks, she is frozen solid on. I don't care what style bearing I use as long as it works. I did pump both zerks full of grease to no avail. I got a price quote of $170 for the short sleeve and bearing retainer, I will be shopping around.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
