Re: Farmall H Drive shaft connection
Posted by slydog on April 19, 2009 at 15:27:58 from (75.104.25.115):
In Reply to: Farmall H Drive shaft connection posted by slydog on April 19, 2009 at 09:42:55:
Thanks for the advice guys. I will try a little more persuasion to knock the bolts out. I just didn't want to break something not knowing if they were threaded in the yoke or not. Not sure if I can get enough of a swing with a hammer as there is not much room with the lift all pump in there. Does anybody know if I can replace the bearing and seal without taking out the lift all pump?
