Farmall H Drive shaft connection
Posted by slydog on April 19, 2009 at 09:42:55 from (75.104.25.115):
I am trying to get the drive shaft connection apart to replace the seal and bearing that goes into the rear end. I took the nuts off of the bolts but I can not get the bolts out. They won't budge. I tried to pry them out with a bar but no luck. Are the bolts threaded into the yoke or will they pound out? I think the ring holes are oblong because it is very loose. The bolts were tight but it is very loose.
