Re: Also --
Posted by makin,hay on April 25, 2009 at 15:22:38 from (69.95.141.6):
In Reply to: Also -- posted by ScottyHOMEy on April 25, 2009 at 15:02:00:
There are 6 bolts and they are all threaded directly into the flywheel. They are all on the outer edge of press plate assembly. Are you saying that there MIGHT be different holes from backing plate into press plate that are threaded to compress springs? I will check if I can see any from insp. cover. Thanks for your help
