JimB2 said: (quoted from post at 11:34:19 05/04/09) Hi, most likely front lip seal on Bosch injector pump. Have replaced 2 in 454 with D179 which is 3 cyl version of D239. Unfortunately you have to remove the pump to replace the seal. Be sure to mark exact location of pump on the mounting flange before loosening any mounting bolts. DO NOT loosen cap screws on pump drive gear. You only have to remove big nut on pump drive shaft via the access hole in the front of the pump drive gear cover. DO NOT rotate pump drive shaft when you have it removed, if you do rotate drive shaft then rotate it 2 revs in direction of travel.
Good luck
JimB
thanks jimB,, I have actually heard this prior, I think you actually suggested it on my first post,thansk,,
is there a way to check that or is it just hit and miss and hope that is teh trouble,, I am sure once it is off I will see if it is cracked or ripped,,
Is this a fairly simple replacement, my book only shows the removal of the unit procedures, but I looked up caseih parts and it seems pretty straight forward,, retaing clip, nut and all in front should come out??
then replace seal and reverse order,, any thing special I would need to look out for?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
