Farmall A PTO question
Posted by Mike Burns on May 18, 2009 at 11:31:19 from (12.31.40.117):
Regarding my Farmall A with a belly mower, is there any speed difference between mounting the drive pulley on the rear or side of the pto? I am trying to gain some rpm for the deck belt and this would be the easiest solution, if it is by chance faster. Thanks in advance.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
