No leave the front tire assembly alone. You have two bolts on each side of the front grill. Take the grill off. Then there is a universal joint on the steering shaft take that loose. There is a big nut on the front of the worm gear. Take that off and the top cap of the worm gear. You then can screw the steering shaft out the front of the gear box. Then unbolt the radiator and lift it out. Hope this helps you.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
