By tricycle, do you mean a single wheel, or is it a two-wheel narrow-front?
The latter is easy. Drive the good tire up onto a block which will allow you to remove the rim with the bad tire from the wheel. No jack!
If a single wheel, you'll need to crib up with some wood blocks and get a jack under the front end of the tractor to lift the front end enough to remove the wheel from the fork. If it is going to sit for any length of time, you want to consider putting a jack stand under and letting the tractor down onto it, especially if it's in an area whre it's apt to get bumped.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
