Re: How do you remove tire from Farmall H
Posted by Johnny Lawson on June 04, 2009 at 12:31:47 from (161.235.195.189):
In Reply to: Re: How do you remove tire from Farmall H posted by ScottyHOMEy on June 04, 2009 at 12:28:16:
It is a two wheel front....narrow front. Do I remove the three outer bolts on the rim or do I remove the tire ftom the center hub area?
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
