Re: Farmall M Hydraulics Question
Posted by mkirsch on June 08, 2009 at 10:55:40 from (64.80.108.56):
In Reply to: Farmall M Hydraulics Question posted by Melvin Ware on June 08, 2009 at 10:17:26:
That is the standard lift-all system. It is a very basic transmission-driven (non-live) hydraulic system, meaning that your foot must be off the clutch pedal in order for it to work.
It is a one-way system as you see it. Power up, gravity down. You can add a two-way valve to make it two-way.
The front elbow on the left and the elbow on the right are the main pressure ports. They operate at the same time. Each one would normally be connected to one cylinder on a loader or a cultivator.
The rear elbow on the left is a delayed pressure port, meant for lifting the rear section (wheel-track scrubbers) of a cultivator.
The lever has three positions. Back is for lift, middle for hold, forward for lower. The lever may also be locked back if you are using a two-way valve.
