Thanks for your explanation of the Farmall M hydraulic system. Now I have several more questions;
1. Since this is a one-way system, I assume the right and left hydraulic ports connect to two seperate cylinders. Both cylinders would raise by hydraulic pressure and lower by gravity?
2. In taking a closer look, I noticed there is a 1/2 inch threaded connection just below and slightly to the front of the right side hydraulic connection. It appears to be plugged with dirt and grease. Any idea what this is for?
3. As for the hydraulic control lever, I'm not sure it's working properly. With engine off, the lever is resting in the forward position. Pulling it back towards the steeing wheel it pivots about 20 degrees until it hits a stop. When released it flops back to the forward position. I don't sense any stop or detent to hold it in the middle position. Is this normal?
4. What are the requirements for hydraulic fluid, how much and what is the proper fill level? Also, should the system be flushed before filling?
5. Is there a good way to tell if the hydraulic system is working without investing in lots of expensive equipment?
6. If adding a 2-way valve to make it a two-way system as you described, I assume that would mean hydraulic connections to both ends of the cylinder(s). If so, doesn't there have to be a return path from the 2-way valve back to the reservoir and if so, how would this be implemented?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
