Re: super c has no spark from coil
Posted by Bob on June 08, 2009 at 14:31:38 from (69.178.228.68):
In Reply to: super c has no spark from coil posted by barney johnson on June 08, 2009 at 14:01:28:
Connect a 12 Volt test light between chassis ground and the primary terminal on the distributor.
Turn on the ignition switch and try to start the engine.
What is the test light doing while you crank the engine with the starter... always "ON", always "OFF" or "FLASHING" as the points open and close?
