Posted by charliet on June 14, 2009 at 04:42:20 from (65.254.172.14):
Having a problem with a 464 transmission (bought tractor new in 1977). Started a few days ago when pulling a hay wagon. When "letting out" the clutch (especially in 3rd or 4th gear; hi or lo range; forward or reverse), there is a very loud "chatter". This continues until the tractor gets moving. After tractor is moving, no noise.
Have removed both covers. No broken gears and bearings appear to be OK. When removing the fluid, noticed no metal in the fluid or in the plugs.
Rebuilt the engine about 4 years ago. During the rebuild, removed original clutch/pressure_plate. Installed an "after market" clutch and pressure plate. The clutch pedal seems "somewhat weaker" than when installed. Pedal "free play" is within specs; pedal spring is OK.
Any help will be greatly appreciated. The tractor is a 3 cylinder diesel. Have always used IH fluid.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
